Make a better design.
alejandro_m16
alejandro_m16
[ FlexSim 21.1.1 ]
How can I join two objects?
For example :
A robotic arm and a rail, so that the robotic arm moves along the rail.
julio_r
Hello Alejandro,
If you drop one element from the library into another in the 3D, the one you dropped will be inside the first one. This mean that if the first one moves, the dropped one will move as well.
For your example, you can use an AGV to move in a rail and a robot inside de AGV, but you have to create it so that first the AGV moves and then the robot starts working.
This is a proof of concept. I just did it to show you how to make a rail so is not as organized as it could.
It is using processFlow, but it can be done differently.
RobotRail.fsm
joerg_vogel_HsH
if you connect a robot to a network node, the robot get a network node navigator assigned in its property page. You can set this manually, too. Then a robot behaves in both worlds as a stationary robot and as vehicle. This behavior was unexpected in the past and it is a bit strange, too.
robot_as_vehicle.fsm
If you want that a robot is reseted to a network by its location, you have to clear the reset position: Right Mouse Button Menu.
julio_r
Did not know this. It is much easier!
Thank you!
