Locking 3D Objects
Locking 3D Objects
park7
Locking 3D Objects
park7
[ FlexSim 24.1.0 ]
Is there a way to lock 3D objects (such as planes, elevators, etc.) from being moved in FlexSim?
Matthew_Gillespie
There are two visual flags you can toggle on objects that would do this:
Protected - If checked, this object will not allow the user to move, size, rotate, or delete the object.
No Select - If checked, this object will not be able to be clicked on the 3D view. To gain access to an object with the No Select flag checked, find it in the Tree Window.
You can toggle these flags by either
  • Right-click on the object, Edit > Protected
  • Click on the object, in Visuals panel press More Visuals, check the Protected checkbox.
Matthew Gillespie
FlexSim Software Developer
