Loading weight
Loading weight
jorge_diaz_velilla
Loading weight
jorge_diaz_velilla
[ FlexSim 22.2.3 ]
Hello everybody:
I wanted to ask if it is feasible to modify in FlexSim (maybe the GIS module) the weight of a load transported in trucks so that this has a physical influence in terms of speed, fuel consumption, pollutant emissions... either in a native way calculated by FlexSim or parameterised in some other way by me.
Thanks in advance.
Jorge Diaz
joerg_vogel_HsH
@Jorge Diaz , just do it. Typically you add some of this in a calculated table for a statistic collector. Or you correlate label values with maximum speed parameter while model runs. I know there are other software tools, which try to implement cost, energy consumption or other financial factors into a model by default options. But my personal opinion is, do this on your own and you get a better adjusted result than from any predefined setting.
jorge_diaz_velilla
I understand, Joerg. Thank you for your help. I'll do as you recommend me: I'll look for a mathematical correlation between all the data then.
Jeanette_Fullmer
Hi @Jorge Diaz,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
kavika_faleumu
Hey @Jorge Diaz, you could try using an AGV System to simulate these physical influences.
You can create different Load Types that cause your AGVs to move at different speeds, consume varying amounts of energy, etc. Then, based on a label like "weight" set on your AGV, you can apply a different Load Type so it moves accordingly.
andrew_o2
Hi @Jorge Diaz, was Kavika F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
