Limiting the data exported in the experimenter?
tr_simulation
Message 1 of 11
tr_simulation
[ FlexSim 22.2.2 ]
In my attached model, I go to the experimenter > view results > statistics table > select from drop down "duration of procedure phases". How do I export ONLY this table to excel? When I export, there is do much data with so many tabs...how do I limit what is exported to only this table?V4_20230207.fsm
Replies (10)
Message 2 of 11
jason_lightfootVL7B4
You can read the table into a global table and export from there:
treenode experimenter = Model.find("Tools/Experimenter");
Database.Connection db = function_s(experimenter, "getDBConnection");
int disconnect = 0;
if (!db.isConnected) {
    if (!db.connect()) {
        return 0;
    disconnect = 1;
Database.ResultSet results = db.query("SELECT * FROM [/Duration of Procedure Phases]");
results.cloneTo("DurationOfProcedurePhases");
if (disconnect) {
    db.disconnect();
Note that the use of function_s means it may not be supported in the future and you would have to change any code that relied on that function should it cease to function correctly.
Message 3 of 11
tr_simulation
Where do I enter this code?
Message 4 of 11
tr_simulation
In addition to my comment below, how is it exported from a global table?
Message 5 of 11
Wherever you like but it makes sense in a script window, in a GUI button, a dashboard button, or in the end of experiment trigger.
Message 6 of 11
Felix describes a method of exporting an experimenter table in this post.
You can probably also use a local result table and export that using an exporttable command rather than having loops to fetch each record and write individual cells.
Message 7 of 11
tr_simulation
Ok, I went to the "advanced tab" on the experimenter, selected "at end of job" and added a "code snippet" and put the code in there. But the results did not appear in a global table. I get the error, "exception: FlexScript exception: Invalid row number: 1 in <no path> at MODEL:/Tools/Experimenter>variables/onEndOfJob"
Message 8 of 11
I just tried using exportPFM("NumScans") from your other post in that trigger and it worked fine so I expect you've made an error. Post your model and we'll take a look.
Message 9 of 11
tr_simulation
My model is attached. I have not done munch beyond the basics in FlexSim, so I need to help to know exactly how to implement your comments with either screenshots or step by step instruction. v4-20230207-jl.fsmThanks for the help.
Message 10 of 11
You just needed to create global table called "DurationOfProcedurePhases" via the toolbox menu.
However, when I deleted the results database and reran the model the output was different. This is likely because you have not specified streams where you have stochastic samples from distributions. Using streams allows you to repeat the runs, debug any that you need to , and is a variance reduction technique - so we recommend using them unless you have a valid reason not to.
Message 11 of 11
tr_simulation
Thank you!
