Label from source to use for port by case
poopatel
poopatel
[ FlexSim 23.0.0 ]
Hii I am creating parts using process flow at Incoming_Modules. I am assigning a label to it 100 and non_100s. I want to split parts from split buffer using port by case but its giving me error saying Type label doesn't exists. Can someone please tell me the issue of why I am unable to split via port by case ?
joerg_vogel_HsH
You add one single label. Different values are responsible to switch by case.
poopatel
I have a label name Type which can be 1 or 2. I have also given a set label in combiner1 but for some reason Split_Buffer is not able to send item as per label to different ports.
Pallet_WIP_req_model.fsm
joerg_vogel_HsH
@poopatel, Queue1 contains only one color type of pallet. It seems Split_Buffer does exactly what you describe.
poopatel
Its not. If you open the model and run it. I want one color in Q1 and other in Q2 but its not working for me.
moehlmann_fe
Observer
Observer
The "Type" label values are strings. You can see this both in the source where you assign them and by the fact that the value is aligned to the left in the label field.
The Port By Case option compares the value to numbers, which the label values are not equal to and thus only the "default" port 1 is used.
Either change the label values to be numeric or adjust the Port By Case so it uses string values as well.
Jeanette_Fullmer
Hi @poopatel, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
