I've built a model for a consolidation warehouse using only process flow (used one connection in the model for the sink) where I built logic for inbound and outbound operations, as well as for the initial inventory of the warehouse.
1. I faced a task error in the outbound logic when I ran the simulation. It is shown in the attached picture below. I'm not sure what causes the label not to be found. Could it by any chance be related to the Find Slot (in Initial Inventory and Inbound Logic) and Find Item (in Outbound logic) queries? As I had some instances where the tokens could get stuck there in some previous runs of the model.
2. I used a timetable to set the working hours and added all task executors and queues. However, the sources couldn't be added as they are not in the 3D model and were added via the process flow. So I wonder if the sources would still be able to generate items in the model during the downtime intervals I set that included the queues to which the sources are linked.
Any help is much appreciated!
You can find the model file attached as well.
