Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Join object to each item packed by the previous combiner
ken_l3
ken_l3
[ FlexSim 21.0.4 ]
DoubleCombinerEx.fsmI have attached an example. I would like to try to join or simulate the joining of two objects. The one object that was previously packed in a container will be what the second object is attached to. I am trying to simulate a part being placed on a pallet and moving to the next workstation that attaches another part. I have been unsuccessful in trying to join the objects as well as changing the 3D shape of the object in the flow bin.
joerg_vogel_HsH
It is question of pointers. The item in a combiner is a container item entering him from entry port number one. Any object on this container is a subnode. If you pack an item on already packed container, then this item gets onto the same level of the previous packed item. If you want to pack it on the previously packed item you have to move it by your own logic. Or in your case you have to change every shape of the items in the container by a loop. You find such a loop in the queue On Message trigger.38789-packing-on-packed-top.gif
packItems2steps.fsm
joerg_vogel_HsH
int steps = current.first.subnodes.length; // items in container
for (int index = 1; index <= steps; index++)
   setobjectshapeindex(current.first.subnodes[index],1);// convert to box
ken_l3
Thank you, this will get me what I need. I will be "attaching" a box on the side of a cylinder and they will be this way through the rest of the simulation. In your model, I was able to separate the objects from the pallet and send them down a conveyor individually. Visually this is what I was looking for.
