item creation by code
priyanka_g
priyanka_g
[ FlexSim 20.0.10 ]
Hello I want to built a basic model where I need to create global table items directly to create in Queue without source using code. And all the labels should be assigned to that item mentioned in global table. I have tried building model but for both part it is assigning same value.
itemcreation.fsm
@Felix Möhlmann
joerg_vogel_HsH
@mary , that is impossible. Even a simpliest look up of a table value involves in some way a source code. If you read a table value, you are accessing him with row and column square brackets behind a reference to a global table node. This is a source code!
In your example you need a row number to read values in a table. Typically we begin with a label called Type for such a task. But any other name will fit, too. Then you are able to fill any other label values or set up a name by look up your table.
moehlmann_fe
andrew_o2
Hi @mary, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
