It is possible to use C++ functions in Flexscript?
robert_s3
robert_s3
[ FlexSim 20.1.0 ]
I tried to declare a function in a node defined as flexscipt. I used the same approach as in C++ where I declared a double() function that returns a value but syntax did not seem to work. Is there a way to declare functions in flexscript at all? Thank you!
regan_blackett
You probably want to look into the "User Commands" write up in the manual. You can create your own FlexScript functions there with whatever parameters and return values you want.
robert_s3
Perfect, this is exactly what I needed
