Issue with Move Object
kags_j
kags_j
[ FlexSim 21.2.4 ]
I am trying to move an object using MoveObject function in process flow and the destination is fetched from a label which was originally fetched from a GlobalTable. I need to move into a specific lost which is predertermined. But after MoveObject is done, the object seems to be missing. not sure what i am doing wrong?sample file.fsm
Jeanette_Fullmer
Hello @Kags,
Like in the other part of your process flow the item needs to be assigned to the slot in the warehouse system and you move the item into the rack and it will be placed in its assigned slot.
sample-file_1.fsm
kags_j
Thanks Jeanette, I see that the boxes are moved into the slots now, but its not 100% accurate, sometimes slot 1 gets the boxes that we actually meant for Slot 2 and also the object color doesn't seem to be set correctly.
Jeanette_Fullmer
Hello @Kags,
Each item needs to be assigned a slot so I created a sub flow that runs a token for each item on the label "items"
sample-file_2.fsm
