Issue to set simulation to end on last item in the sink
howy3508
howy3508
[ FlexSim 24.0.2 ]
I want the simulation to end when the last item enter the sink. Using the similar code from this post but I am not able to stop the simulation.
How to end simulation run after last flow item being processed? - FlexSim Community
Also, the 3rd shift operator never get used. Am I setting this up correctly?
Issue - Process to end, 3rd shfit operator.fsm
jason_lightfoot_adsk
In an entry trigger:
if (current.stats.input.value==8)
      endreplication(0);
Operator3 doesn't get a job since it is stopped the whole time. When you stop a dispatcher it will also stop its outobjects. Since you have timetables for the dispatcher and the operator that overlap there is no time when both timetables are 'on shift'. Remove the timetable you don't need, or alter them so that there is a period where no scheduled down time is active on either of them.
Jeanette_Fullmer
Hi @Howard, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
