- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim (other) ]
v 16.1
I'm trying to get an AGV off of a spur following an unload by using a Travel activity in Process Flow to send it to a temporary parking spot, but if a travel task arises while the AGV is en route to that parking spot then I want it to be preempted by the new task.
If I create a Task Sequence in Process Flow, I can assign a priority and preemption rule that will apply to a Travel activity later assigned to that Task Sequence. If I simply add a Travel activity assigned to the AGV, there is no place to assign priority & preemption. Is there an implied/default in effect?
Do I have to go the Create Task Sequence/Dispatch Task Sequence Route?
