Is there a way to open a dashboard via code?
gina_lasure1
gina_lasure1
[ FlexSim 16.2.0 ]
Opening a GUI is very simple with the "createview" command combined with the GUI's path in the tree - but I cannot convince a dashboard to open correctly with the same command. Has anyone done this successfully?
Matthew_Gillespie
You need to use the "dashboard" application command, for example this opens the first dashboard in your model:
applicationcommand("dashboard", Model.find("Tools/Dashboards").first);
Matthew Gillespie
FlexSim Software Developer
albert_l
Hi Matthew, when I ran this code, the dashboard window opened but the dashboard didn't appear in the ToolBox list which lists out things like: All user commands, all global tables, all groups, all dashboards. Is there a way to create the dashboard and reference it afterwards in order to: change the dashboard name, add charts and graphs? Thank you.
Matthew_Gillespie
That command doesn't add a new dashboard. To add a new dashboard use this command:
treenode newDashboard = applicationcommand("adddashboard");
Matthew Gillespie
