Is there a lighthouse event by a command?
joerg_vogel_HsH
Mentor Mentor
joerg_vogel_HsH
[ FlexSim 19.2.1 ]
I would like to put a command into my logic, that when I execute the command an event is created and I can listen to. The method should work in Process Flow logic as well in 3D trigger logic. I need it to implement a safety function in a group of processors like a emergency stop. I know the message feature. But I’d like to listen on an event like OnMessageSend. Or is there the possibility to listen to user events.
Regards, Jörg
JordanLJohnson
You can use executesubflow(). That will create a token that will generate events that you can listen to.
Jordan Johnson
Principal Software Engineer
joerg_vogel_HsH
@jordan.johnson, thank you for your answer.
