Is the global variable causing the exception "Invalid SqlQuery Object "?
ITAsset
ITAsset
[ FlexSim 16.2.2 ]
I am trying to query a list to get a token that does not have the same material ID as the another token. The "other" token is not the one doing the pulling so I stored the material ID for that token in a global string array so I could access it.
Why is this pull then invalid?
lbsMaterial is a label field on the list.
adrian_haws
There is not extensive Flexscript support in SQL. If you need to use a value from a global variable, you can create a label and use that in your SQL query.
