Is it possible to pass the result of a query as a function parameter?
guiroehe
guiroehe
I wonder if it is possible to pass the result of a query as a parameter in a function call. If so, what is the specification for the variable in the function code? I tried with Table, but the function receives an invalid content.
Also, how one tests if a query is NULL? objectexists(...) does not seem to work.
Thank you.
jason_lightfoot_adsk
You can use a clone of the table result to cast it as an array and pass it as a variant parameter.
guiroehe
Hi, @jason_lightfoot_adsk ,
thank you. It worked.
I am implying that this way the query looses its "table" characteristics, correct (column names, indexes, etc.)?
Thank you once more.
Yes - you lose that information in a array.   You could alternatively create a Map of the table for better referencing and pass that to your function - try mapFromTable() here.
guiroehe
Thank you very much!
