Is it possible to delete Object by Code?
martin_k5
martin_k5
[ FlexSim 21.1.4 ]
I would like to ask, if it is possible to delete an object by code? I was searching through the community and I did not find any advice. Does anyone knows please?
Thank you.
Martin
mitregatomasz90
Hi
destroyobject(your_object)
krzysztof_jurczykF5GXD
Use such a syntax:
Object objectCodeName = Model.find("Yourobject");
objectCodeName.destroy();
Anyway you can use old syntax - destroyobject("objectCodeName") but I wouldn't reccommend it.
patryk_u2
Try this code "destroyobject()"
martin_k5
Thanks a lot.
Matthew_Gillespie
@Patryk @Martin K5 @Tomasz MG
treenode.destroy() is the preferred method since destroyobject() is a deprecated command.
Matthew Gillespie
FlexSim Software Developer
