Is it possible to access data in this dashboard table?
rhramac
rhramac
[ FlexSim 23.2.2 ]
Is it possible to access data from a throughput dashboard as shown below? For example, how do I average the throughput and write it to a global table?
jason_lightfoot_adsk
The easiest way is probably to install the chart and then read the data from the calculated table/stats collector.
rhramac
Thanks, I have never used "install" feature. The documentation says it will add statistics collector, calculated tables to tool box. Do I then simply refer to these tables using a SQL query?
Yes, that's a good way of transforming and transferring the data.
Hi @Rahul R, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
