Is Experimenter facing a problem in v2016?
lucas_antonio_risso
Message 1 of 22
lucas_antonio_risso
[ FlexSim 16.0.1 ]
I am running the Experimenter with 100 replications for 48 performance indicators, and the results are not being showed after the running, like showed in the image below. However, if I reduce the number of KPI's or the number of replications, it runs normally.
Has anyone already faced a similar situation? By any chance, is there a limit for the settings?
Please, I appreciate if you could check my model. experimenter-blank-results.fsm
Thank you for your help.
Replies (21)
Message 21 of 22
philboboADSK
Seemed to fix it for me: 914-experimenter-blank-results-pb1.fsm
Note: I only changed LT 7 and 8 because those ones were showing issues. You should probably fix all of them.
Phil BoBo
Sr. Manager, Software Development
Message 22 of 22
lucas_antonio_risso
It worked. Thank you for the attention. Your answers helped me a lot.
