Input record of machines not working
luis_rodrigues
Message 1 of 11
luis_rodrigues
[ FlexSim 24.1.0 ]
Hi, I'm working on a model which the transporters load the machines.
In my model I have a statistic collector that tells me how much of each material goes to the machines.
I've introduced AGVs to the model and somehow this collector stopped working properly, and it was working fine on the non AGV model.
For example, the ML12 is getting way too much material then what is supposed.
I don't know if this material is actually getting loaded or is just the collector not working
V1 27-09.fsm
Thank you in advance!
Replies (10)
Message 2 of 11
moehlmann_fe
Observer
Observer
I assume this happens because two AGVs can now get materials for a queue at a time where previously, because there was a single fixed transporter per pair of queues, this was not possible. The second token to enter the Load Materials subflow would not take into account the material that is already being replenished by the first and thus potentially doubling up on the input.
If it's not a requirement that parallel input tasks are possible, I would try to limit the subflow to one token per queue at a time. (Also include the "Acquire Transport" activity in the zone to not have acquired AGVs that wait for the zone to clear)
Message 3 of 11
luis_rodrigues
If I understood correctly, if I do that I won't be able to load two machines at the same time for example right?
I can't change the logic of the model because I'm going to compare it with the base model without AGVs.
Anyway I've tried to do as you said and I'm still getting too much material for ML12 for example.
Message 4 of 11
moehlmann_fe
Observer
Observer
As far as I can tell you are comparing the numbers from the model with historic data? Are you sure that the numbers are based on the same amount of throughput? Have you compared the amount of delivered material to what would be expected based on the number of times each recipe was run?
I don't see anything wrong with the logic. For each token it checks if enough of each material needed in the recipe is present in the queue. If not it moves as many items of that type to the queue as are mandated by the "MaterialType" table.
Message 5 of 11
luis_rodrigues
@Felix Möhlmann somehow I can't see the last answers you sent, althought I can read the last answer in my email but I can't see the image, can you send me again please? Sorry but I don't know whats wrong with this post
Message 6 of 11
moehlmann_fe
Observer
Observer
Edit the "Empty Pallet" Decide to this, so pallets aren't assigned to more than one AGV.
Message 7 of 11
luis_rodrigues
Thank you, now it's working fine :)
Message 8 of 11
luis_rodrigues
Hi @Felix Möhlmann I don't know if you want me to create another topic for this but I'm analysing the results of the Simulation between the model with forklifts and the model with "AGVs" and I'm seeing too much variation in the output of some machines like ML02 etc.
Is this "normal" or something is wrong?
(Sorry to border you)
mlall-forklifts-fm.fsm
mlall-agv C1.fsm
Message 9 of 11
moehlmann_fe
Observer
Observer
Can you upload the models again? They didn't attach to the post properly.
Message 10 of 11
luis_rodrigues
mlall-agv C1.fsm
The travel speed for the AGVs is 1.25m/s but right know I can't change it (I don't have my pc with me)
But the values I showed previously are for this speed
Message 11 of 11
moehlmann_fe
Observer
Observer
As far as I can tell the number of AGVs in area 1 (AGVGroup 1) is simply to small. In the other model there are 5 transporters vs only 4 AGVs. Sharing all tasks might also lead to more empty travel.
The most affected combiners are those that use a palletizer (2, 4, 5, 6, 7) because clearing the palletizer and bringing new tables has a lower priority than other tasks.
