Incorrect column names in output per hour template
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 21.2.0 ]
If you add an output per hour line graph dashboard to your model and take a look at the table that is behind it you will see that the table has incorrect column names. It would be nice if this could be fixed in the future. You can see the problem in the picture below. The first column should be Time and the second should be Object.
Thank you for your time,
Patrick
eric_m3
Good observation, I'll add a case to the dev list. If you need a workaround, you can install the chart and manually change the column names in the Output By Hour Collector.
