Improve forklift movement
bernabe_n2
1 View
bernabe_n2
[ FlexSim 18.2.3 ]
Have a great day Communit, im working in a visual model using forklift as a task executer
When forklift load and unload an item y need to visually reverse in a path and then continue to the next location
I have checked some topics here in the answers and i add kinematis
to the operation but it doesnt works and forklift do the same movements.
Frankly i have never use kinematics in forklift operation
I appreciate your soon reply
Thank you, BN
joerg_vogel_HsH
Maybe it is just a parameter in the transporter you have to set to let him travel in reverse direction.
flip threshold
If it is something total different you want to achieve, for example a device on the fork to move in y-direction, then I suggest that you add a drawsurrogate object into the fork node and add an animation for this object. If this is the case, please come back and describe it a bit more. Thanks!
bernabe_n2
Thank you @Jörg Vogel, i tried and at first glance it works correctly
Regards
