Importing array data from excel to global table?
rajankur6494
rajankur6494
[ FlexSim 20.0.10 ]
Hi Team,
I am importing array data from excel as Array[2]: {Room1, Room2} but it is read as string in assigning label logic.
How can I get it back to array?
Or what is the best way to import such data since user will be interacting from excel only?
Thank you!
joerg_vogel_HsH
Resolve your data in excel to single values only: strings or numbers!
jason_lightfootVL7B4
If you can't do as Jorg suggest and keep single values in the cells then you can postprocess the import using the string.split() method
rajankur6494
Hi @Jason Lightfoot@Joerg Vogel,
I have built my model logic to work for array. So, after importing data in cells, how can I convert that into array for every row in global table?
Thank you!
Table t=Table("GlobalTable1");
for (int n=t.numRows;n>0;n--){    //iterate through the rows
    string s=t[1];   // row n, column 1
    Array sArray=s.split(",");   // get the array using comma delimiter
    t.cell(n,1).value=sArray.clone();  // overwrite the table cell value
If you just have your values comma separated in Excel the above code will convert the column to arrays.
ConvertTableCellToArray.fsm
rajankur6494
Hi @Jason Lightfoot ,
I couldn't open this model since I am using version 21.1.5.
Thank you!
