Import value from different global table into current global table?
pert_p
pert_p
[ FlexSim 22.2.1 ]
Can I pull the value from other global table into current global table by searching index roe, column coding C++? What the command that I have to use?
joerg_vogel_HsH
a table is a static construct. It has not a code executer per default. You can write code in a cell and let it execute from a process. You can write content from anywhere into cells. A table cell has got write and read abilities. Perhaps you take a look into the Flexscript api for tables.
Jeanette_Fullmer
Hi @Pert P, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
