Import external 3d model into Flexsim
ka_ho_l
ka_ho_l
[ FlexSim 20.0.0 ]
Hi everyone, I'm new to here, I wanna ask can I import external 3d model into Flexsim. Like SketchUp or Unity. For create a 3d model, which software is relatively easy to master? Thanks so much.
joerg_vogel_HsH
Yes, there are some versions of SketchUp model shapes, that you can import. I know it is difficult to read a manual or to use search tool of a forum. But please do it! If you run then into a problem, then you can ask a detailed question.
ka_ho_l
Jory, Thanks for your reply. I'm doing it for my final year thesis. If using SketchUp to build the 3D model, then import into Flexsim to conduct simulation, I think of several problems may encounter. Does the file size matter? Like if the file size exceeds certain GB, it cant import to Flexsim. Any limitations on import SketchUp into Flexsim? Thank you so much
joerg_vogel_HsH
allister_wilson
Potential technical limitations aside, you'd probably want to avoid using a multi-gigabyte 3D model for real time rendering in any software, FlexSim included.
