[ FlexSim 23.2.0 ]
I would like to ask if it is possible to import custom object by code?
Thank you,
Martin
[ FlexSim 23.2.0 ]
Thank you,
Martin
I assume you want to reuse a customized object from one model file in a different model. You need to export your customized object into a user library file. This file can you load into a new model file manually or always for any new model by environment settings. In a case where you need a set of different objects you put all customized objects into a single user library and export this.
Adding a user library by code makes only sense, if you are absolutely sure this action takes only place once during existence of your model or you need structures which deletes and unloads user library objects on each simulation run start.
https://docs.flexsim.com/en/23.2/Using3DObjects/CreatingCustomObjectsAnimations/CreatingCustomLibrar...
Is this somehow possible?
Thank you.
In your preferences set the user library to load every time FlexSim starts and then create a script to copy instances from the library into your model.
Hi @Martin K5, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
