Im using agv's and they don´t respect distance between them, any advice?
alex_ch
alex_ch
[ FlexSim 18.0.2 ]
bk.fsm
Im using process flow and networks node, the problem i have is that agv´s dont respect the distance between them and in a certain point they pass through the next agv, im using different velocities for each type of agv.
btw, is there a better way to simulate this process?
I dont really know about agv´s at flexsim 😞
SCHamoen
@Alex Gf If you open your nodes you can change the connection from passing to non-passing. That way they can not overtake eachother. But if you really want to look at AGV's use the AGV module instead of the nodes.
