if we connect Task executer to network node, heat map doesn't work
nikhil_rane9NJAU
nikhil_rane9NJAU
[ FlexSim 23.2.1 ]
I have connect task executer to network node, then added A* for heat map, when I added task executer in A* it disconnect network node and follow random path.
Is there any we in which i can use network note in heat map
moehlmann_fe
A task executer can only be connected to a single navigator at a time.
You can check out the custom heat map object @Jason Lightfoot posted here (see comments under the answer). It works by tracking the location of the task executer and does not depend on the navigator.
