This is a follow-up to my previous post, "How to create a simulation that accounts for non-processing time." I would like to add a new requirement based on the same simulation data.
In the current model, is there a way to display the exact time (in the format "HH:MM:SS") at the moment when 200 items have finished being processed and arrive at the queue "QCPS0828_6_06" (connected to the 1st output port of the processor)? If possible, I would like to apply this to the 2nd port, 3rd port, and so on.
Please consider the following constraints:
I am open to using labels or specific values, but I would prefer a solution that does not use Process Flow.
If possible, I would appreciate it if you could provide a sample model or data.
I have already tried using Global Tables and Statistics Collectors, but I couldn't get them to work as intended. I would appreciate your guidance on this, along with the points discussed in my previous post.
