Message 1 of 15
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 20.0.10 ]
我想建立一個agv模型,該模型有兩輛車(一輛大車隨身攜帶的小型車和一輛小車隨身攜帶的物品),大車直行至固定點,小車橫行至固定點,
[ FlexSim 20.0.10 ]
Via Google Translate:
I want to build an agv model. The model has two cars (a small car carried by a big car and a small car carried by a small car). The big car goes straight to a fixed point, and the small car runs horizontally to a fixed point.
Hi @霈倫,
Have you worked through the AGV tutorials? That would be the best place to start. Then come back with any questions that you have as you start to build your model. Be sure to attach your model file and explain how far you've gotten and where things are going wrong.
As you go through the tutorial, if you have any specific questions, you can ask those here, too.
i finish AGV tutorials!!!but i didnt know how to do this problem
Create the path you described. Place control points where the AGV's are supposed to start and finish. You can then either...
1 Connect queues with flow items in your model and use the AGV's as transporters.
2 Use process flow to create a custom task sequence using load, unload, and travel activities.
我了解您的模型,但是沒有回答我的問題
Google Translated: "I understand your model, but did not answer my question"
Perhaps we need a better description or Google Translate isn't doing a good job. Can you provide more information or a video?
https://v.qq.com/x/page/e05060qu6cz.htmli
i need to do this!!
You can find your solution model in this forum after searching keyword "shuttle" or "autostorage" agv.
i do it ! but autostorage do not help me !!sorry
Anthony Johnson has published a model, which uses moles to move pallets in a deep rack cell. The moles are put to different cells by transporters. You will exchange those transporters by other AGVs and you lift the mother AGVs by elevators at an end of a rack. The AGVs will move by travel to location tasks.
test1
Hi @霈倫 ,
Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
