HRESULT-2147024703
HRESULT-2147024703
fidel_tj
HRESULT-2147024703
fidel_tj
[ FlexSim 22.1.2 ]
I am trying to install Flexsim 2020 v. 20.1.2 on a MacBook Pro M1 running Parallels Windows 11, but the error describe above stops my installation. What could I do?
Ben_WilsonADSK
Hi @Fidel Tj ,
You can get around this error by installing using the .msi rather than the .exe. You can download the .msi installer in the same area of the website where you find the older installers for version 20.1.
Specifically, the .msi installer does not include the OPC components that are causing your error. See Can I install FlexSim without OPC?.
The suggestion to try the .msi installer is included in our article FlexSim installation or startup error (see item 6), where you'll also find other suggestions that can be helpful for other errors.
Let us know if you have any questions.
fidel_tj
Thanks a lot @Ben Wilson for your help, problem solved.
