How use tracked variables?
kevin_teodoro
kevin_teodoro
I am using flexsim 2016 update 2 and i dont find in toolbox the tracked variables and global variable. Someone knows what it is happening?
cameron_pluim
@Kevin Teodoro, You can add tracked variables to your model through the toolbox going through Statistics->Tracked Variable. See the picture below:
Global Variables are similar, but they are found in Modeling Logic ->Global Variable
kevin_teodoro
I have the Trial Version, so i think i don have this feature
sam_stubbs
It looks like you're using the "Express Version" of the software which doesn't have the Modeling Logic items like Global and Tracked variables.
kevin_teodoro
I just have theses features if I pay for a license? I am track variable with process flow?
sam_stubbs
For Global and Tracked Variables that is correct. For Process Flow you still should be able to create Process Flow variable which you can use for Process Flow projects. If you're interested in the other features you could contact the distributor closest to you, which you can find here: https://www.flexsim.com/contact/#SouthAmerica (It looks like you're in Brazil, so you should see contact information there for FlexSim Brazil.)
