How to write scripts to find the best job sequence for the attached model ?
RUEI-CHENG_LAI
RUEI-CHENG_LAI
[ FlexSim 23.1.2 ]
1.Solutions (the job sequence) must be written in the “Sequence” column of the “Job” global table in the FlexSim model.
2.The global table CMAX will automatically compute the makespan performance after the simulation execution.
3.There are two "queue" because I want to start processing after sorting job sequence.
4.The following are FlexSim model and machine data.
Two Parallel Machine Data.xlsxParallel Machine Scheduling Problem -hw.fsm
Jeanette_Fullmer
Hi @Henry,
Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
