How to use the experimenter to see the impact of using TrafficControl?
hebah_m2
hebah_m2
[ FlexSim 18.0.10 ]
How to use the experimenter to see the impact of using or not using the Traffic Control on waiting time and staytime in Qu?
I need to run an experiment on the traffic control to see the impact event of stop using the TrafficControl or doesn't work on one side?
I attached the file of flexSim to look around and understand my issue. It is Port and has two sides (one serve for ship and the other for barge), also, between NN9 and NN10 must be just one vessel at a time.
joerg_vogel_HsH
Please attach the mentioned file. Thanks.
hebah_m2
small-port.fsm
Sorry about that. I attached it. Thank you
benjamin_w2
@jordan.johnson can you use the expiramenter to enable and disable network nodes on a traffic controller?
JordanLJohnson
I don't know a good way to enable or disable the Traffic Controller in the experimenter. Consider the following workarounds:
  • You could copy and paste all the 3D objects in the model, and get two side-by-side systems working, where one uses the traffic controller, and the other does not.
  • You could run the experimenter on each model separately, then compare the results. It may be helpful to export the results to Excel or some other analysis tool.
Jordan Johnson
Principal Software Engineer
braydn_t
@Hebah M2
Did Jordan's answer work for you? If so, can you accept his answer by clicking the accept button? If not, please let us know what else can we do to help you.
