How to use SQL queries in a DLL project?
mark_s3
mark_s3
[ FlexSim 17.1.6 ]
When I build a DLL function, I need to use the query function to query a global table.
But I found that the code copied directly FROM the flexsim code editor, such as query("SELECT A FROM TableName WHERE B >0"), will report an error in visual studio.
I've tried many ways, but none of them worked.
How can I solve this problem?
philboboADSK
Using FlexSim's SQL query() command may have worked in C++ at some point, but I don't think it does currently.
If you want to use query() or Table.query(), you might need to execute FlexScript to do so right now.
Phil BoBo
Sr. Manager, Software Development
