How to use "OnKillFocus" Attribute
lin_r2
lin_r2
[ FlexSim 20.2.3 ]
I want to use "OnKillFocus" attribute in GUIs, but I can't find it. I try to make it by myself, but not useful. Please help me. Thank you.
jason_lightfoot_adsk
Attached is an example showing that OnKillFocus on an edit field can be used to set a variable as soon as you click away from the edit.
OnKillFocusExample.fsm
Ben_WilsonADSK
Hi @Lin Ray, was jason.lightfoot's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
Note - if you want to add a node then in the tree highlight the intended container node and press Enter, then press T to add text data for your code. Click the name to rename it OnKillFocus. To add a node after another, highlight the intended predecessor and press the spacebar. These nodes need to be at the primary attribute level of the view accessed by clicking ">" next to the view node in the tree.
