[ FlexSim 21.1.2 ]
I'm using the Fluid library and trying to use the "contextdragconnection" to make some connections in the model while it is running.
The problem is that when process flow makes these connections, the fluid does not leave the tank (the code snippet is already opening and closing the object's ports).
How can I do this?
Thanks!
