How to use Navigator getcost to estimate two cp points?
oceanbluesky1993
oceanbluesky1993
[ FlexSim 23.2.0 ]
I want to estimate the route distance of two cp points through Navigator getcost. However, I got some error, hope I can get some instruction to solve the issue, thanks!
task-43-using-elevators-with-agvs-2-elevator.fsm
moehlmann_fe
You need to declare the variable "a".
Navigator nav = Model.find("AGVNetwork");
double a = nav.getCost(Model.find("ControlPoint12"), [Model.find("ControlPoint66"), 0], 0);
return a;
To get the distance between two CPs you can also use the command cpdistance().
