How to unpack the item on conveyor without using Seperator
tushar_hazare
tushar_hazare
[ FlexSim 22.2.3 ]
In my model there are conveyor B & C. I want is pallet will go to conveyor C and box will go to conveyor B without using Seperator. 1671188468973.png
Thank You in advance.Unpack Sample model.fsm
joerg_vogel_HsH
As far as I know you need an entry transfer to get items in a conveyor system. You can move or separate items out of a container, but then you have to move those items in an entry transfer.You can get an entry transfer by a connection to a conveyor typically from a queue. In most cases it is then a side entry transfer, which is near a station, decision point or a photo eye to emulate the separation process. The entry transfer is responsible to find space on a conveyor to insert an moved item. unpack-sample-model_JV.fsm
Jeanette_Fullmer
Hi @Tushar H, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
tushar_hazare
if i want to use operator to transport the box from conveyor A to conveyor B then how to map
joerg_vogel_HsH
Exit transfer to entry transfer. In Exit transfer activate USE transport.
draw an ”a” connection from A to B conveyor.
Any additional enhanced question goes into a new question? OK.
