How to unload the item from AGV to specified location
wie_k
wie_k
[ FlexSim 22.2.2 ]
This model is semi-finished
I want to make a partitioned AGV operating system , use queue to connect the two parts of the agv system , but now i cant put the item from agv into queue(input_point)
how can i fix the problem ? ( rookie of agv and a* Navigation
流管專案.fsm
moehlmann_fe
Observer
Observer
You use "token.item" in the Unload activity, but the label that refers to the item is called "Item", with a capital "I".
The Process Flow in the model you uploaded seems to be corrupted somehow. I am getting an error message when I reset the model. So I couldn't test the model further. The error in your screenshot should be fixed by adjusting the label though.
wie_k
i fixed the “token.item” BUG yesterday , But now I get an error during list interaction ,in my part2 processflow it cant pull the list correct , how can i fix it?
