How to uniformly modify the process time of multi machines by parameter table?
sia_sengchoon193
sia_sengchoon193
[ FlexSim 21.1.5 ]
How to use the parameter table to uniformly modify the processing time of multiple machines?
I know how to use the parameter table to modify the number of different objects,
But I'm not sure how to uniformly modify the settings of multiple machines, such as processing time,
I have many combined machines,
I need to modify their processing time uniformly,
How can I add this setting to the parameterization table?
alp-without-pod-0508.fsm
Jeanette_Fullmer
Hello @Sia Sengchoon193,
In the processing time field, you can select a picklist option that selects the parameter.
or use the code
Model.parameters.ProcessingTime // note: ProcessingTime is the name of a parameter I created in the parameters table
sia_sengchoon193
@Jeanette F Thank you, I have found a similar way, I don't know if it is the same as yours, but thank you very much for your help!
