how to trigger the plane that person step on it
martin_c10
martin_c10
[ FlexSim 20.0.10 ]
螢幕擷取畫面-247.pngchooseelevatorbank-2.fsm
I want to collect person's label and add entry time to global table when person step on the plane , how can I set trigger event?
jason_lightfootVL7B4
This is easily done with a Statistics collector that listens to the completed Travel tasks - which are in turn detected in the process flow.
See attached model.
chooseelevatorbank-2_jl.fsm
Matthew_Gillespie
You can listen to the patient's elevator events to get these time stamps. You also don't really need all those floor spots. You can just send patients to an x,y,z position in front of an elevator. Here's an example.
ChooseElevator.fsm
I'm listening to the patient's OnAStarElevatorBankArrival, OnAStarElevatorEntry, OnAStarElevatorExit, and OnAStarElevatorBankContinue events.
Matthew Gillespie
FlexSim Software Developer
martin_c10
thanks
martin_c10
thanks
martin_c10
Sending patients to a fixed location is a great workaround, and the custom code you created fulfills my target, you are a genius
martin_c10
This solution is a truly convenient way to get the data, appreciate
