How to store matched token data after pull from list
anggoro_p
anggoro_p
I have made a pull from list activity under a query and it seems working well. To make it sure, I want to store the data of matched and unmatched tokens, so that I can trace them. For the unmatched tokens, I have added a new label "failed" into the data
Thanks a lot
sam_stubbsYXX86
So I'm not entirely sure what you are asking. If a token is not pulled from the list, by default it will just stay on the list, and not move from that pull activity. However, if you have a Max Wait Timer set, and the maximum time is met before being pulled, then also by default it should set a "Failed" label to the token. Is this what you're looking for?
