How to store field values from a list into an array
stefano_l
stefano_l
[ FlexSim 19.0.0 ]
Hi, I'm trying to store field values (not the header) from a list into an array. In particular, I pushed items in a list called ListBox and now I want to store values of Dimension field into an array.
Is there a way to do it?
Thank you in advance for your answer.
joerg_vogel_HsH
You can get access to the list entries by a table.query and the clause ARRAY_AGG()
Array myArray = Table.query("SELECT ARRAY_AGG(Dimension) FROM ItemList1")[1][1];
this is shortest way to get the entries of a field of a list.
My first Approach is a bit longer. You do a Table.query for the List. Then you clone the result table into an array. Unfortunately the array is 2-dimensional. You append each result cell value in a one dimensional array by an iter( ..) - ation.
The table.query works only on global lists.
global-list-field-to-an-array.fsm
stefano_l
@Jörg Vogel Thank you for your answer, I'm using a global list. How can I do it by script?
joerg_vogel_HsH
Array myArrayAlt = Table.query("SELECT $2",
	rslt.length,
	myArray.push(rslt.shift()[1])).clone()[1][1];
an alternative source code line
