How to stop the TE to prevent it from leaving the charging area?
pui_fong_c
pui_fong_c
[ FlexSim 18.1.1 ]
TE will quit the charging area once there is a new task. Is there code to reject the new task or lock the TE before the battery reach a target level?
joerg_vogel_HsH
Can you describe, how you control the AGV? Do you use the Process Flow template? Do youhave built the model by a tutorial and control the behavior in triggers of the objects?
The quick answer is: give the taskexecuter something else to do, like a delay task or a utilize task by dispatching a own created tasksequence or by an activity.
