How to share a Color Palette to a Library file?
clairekruppGhafari
Observer Observer
clairekruppGhafari
Observer
Observer
[ FlexSim 21.2.2 ]
I have created a standard Color Palette that I want to copy to other models and share with my colleagues.
It does not seem to have an "add to Library" button like other elements do, and I can only duplicate it inside the same model.
Is there a way to copy it to another model?
Thanks!
Matthew_Gillespie
You can use applicationcommand("addtouserlibrary") in a script window to add the palette to a user library.
applicationcommand("addtouserlibrary", <object>, <rankOfUserLibrary>, <autoInstall>);
This will add the color palette to the first loaded user library:
applicationcommand("addtouserlibrary", Model.find("Tools/ColorPalettes/ColorPalette1"), 1, 0);
Matthew Gillespie
FlexSim Software Developer
clairekruppGhafari
Observer
Observer
Thanks @Matthew Gillespie . So it sounds like I have to create at least one user library first?
Matthew_Gillespie
Yes. Or you can also create a user library through code.
applicationcommand("newuserlibrary")
Matthew Gillespie
clairekruppGhafari
Observer
Observer
Thanks!
