How to set the palletizing ability to a box flow item?
joerg_vogel_HsH
Mentor Mentor
joerg_vogel_HsH
[ FlexSim 17.2.3 ]
I want to add a packing method to a flowitem. The Flowitem is the result of a joining process in a combiner. I have copied the behaviour node of a pallet flowitem from the flowitem bin, but an added other flowitem isn't stacked correctly as it would happen with a pallet flowitem. What should I do to get the same behaviour in a box flowitem as the pallet flowitem does?
Object current = param(1);treenode activity = param(2);
Token token = param(3);
treenode processFlow = ownerobject(activity);
Object item = token.item;
Object binPallet = model().find("Tools/FlowItemBin/Pallet/Pallet");
treenode palletBehave = binPallet.find(">behaviour/eventfunctions");
treenode itemBehave = item.attrs.assert("behaviour");
createcopy(palletBehave,itemBehave,1);
itemBehave.rank = 2;
rebindobjectattributes(item.attrs.behaviour);
Custom source code in Process Flow activity
Picture of the model - the pallet in Queue1 doesn't stack the flowitem as the pallet from Queue2.
arunTTT2P
Hi @Jörg Vogel,
Instead of changing the behavior of the box to pallet on the combiner, you can release pallets from source 1 & 2 with the 3d shape of box with proper size by using the exit triggers of the sources. Then after changing the visual using process flow, packing will happen normally.
On top of that, you can avoid the custom code in the process flow. I think.combiner-model.fsm
Arun KR
joerg_vogel_HsH
If I do the same in the Flowitem Bin, before I start a model run, the copied behaviour works. Is it a problem how the flexsim engine interpret the source code when the model is translated into machine code. I am copying source code to an item after the translation process had been finished.
joerg_vogel_HsH
@Arun KR
your answer seems the easiest method to get the stacking method to an box item. I have tested the command copyattibutes( ). But this command doesn't copy the behaviour node to the box neither. Thanks!
