How to set speed for AGV Vehicle through code?
gilbert_jerald
gilbert_jerald
[ FlexSim 18.0.3 ]
Hi
In my model, I am using two AGV that transfer item from Queue1 to Queue2.In this, I have to set different traveling speed for two AVG at OnLoad and Onunload state through code that travels on the same path.
For example:
Agv1: Will move 5meter/sec at OnLoad condition and 7meter/sec at OnUnload Condition.
Agv2: Will move 4meter/sec at OnLoad condition and 6meter/sec at OnUnload Condition.
Note: I want to set speed for these two AGV through code.
I have attached the sample model for your reference agv-samplemodel.fsm
Thanks in advance for your valuable answer.
monika_k
If I understand correctly you would like to specify different speed table for individual AGV, right? To do it you need to open “Network Properties” and then add a new AGV Type (by plus).
Then you set speed values. After that you need to add AGVs to a proper AGV Type. Just select AGV and in “Quick Properties” window change Type from dropdown list.
12160-set-agv-type.png20180530-agv-type.fsm
I attached model with those changes.
