How to set location by code in Proccess Flow Create Kinematics?
Troy7
Troy7
[ FlexSim 22.2.0 ]
I tried to set the x location by custom code in create kinematics:
here is my code:
It just simply return 1, but system console throw an error:
time: 0.000000 exception: FlexScript exception: Invalid down cast. Object is not an instance of the target type. at MODEL:/Tools/ProcessFlow/ProcessFlow/Create Kinematics>variables/xLoc
I don't know how to solve it.
What is the correct way to set the location by code?
philboboADSK
This looks like a bug with the header of that field. The kinematics node is passed as param(4), which is a treenode, not an Object.
Change "Object" to "treenode" on line 5.
I'll add a case to the development list to fix this code header.
Phil BoBo
Sr. Manager, Software Development
Troy7
Thanks a lot, solved my problem.
Matthew_Gillespie
@Troy
This issue is fixed in 23.0.9 and 23.1.3 released today.
Matthew Gillespie
FlexSim Software Developer
