How to set HTTP status in from serverinterface/queryhandlers
sastanin
sastanin
[ FlexSim 24.0.2 ]
We use custom query handlers in MAIN:/project/exec/globals/serverinterface/queryhandlers to interact with our models via FlexSim Webserver, as documented in https://docs.flexsim.com/en/24.0/Reference/DeveloperAdvancedUser/Webserver/Webserver.html#InstanceQu...
What I noticed is that queryinstance always responds with HTTP status code 200 OK, and there doesn't seem a way to set a different status. In particular I'd like to be able to reply with 400 Bad Request or 404 Not Found.
I noticed than many default queryhandlers use this or similar code:
setnodestr(replyNode, "HTTP/1.1 404 Not Found");
return replyNode;
However, if I try to do the same and set replyNode to be the header of the response, it still ends up as the body of the response with a status 200.
For instance, this HTTP request
http://127.0.0.1:10001/webserver.dll?queryinstance=TestModel&instancenum=1&getnodedata=doesnotexist
results in a response with HTTP status code 200 and the body fakes to be an HTTP response:
So the question is, what is the correct way to set HTTP status code from the instance query handler?
FlexSim 24.0.2
Jacob_Gillespie
@Serge A
It looks like we accidentally removed some new line characters that our code was relying on to check for a valid http header.
It used to be like this:
setnodestr(replyNode, "HTTP/1.1 404 Not Found\r\n\r\n");
When replyNode has byteblock data it first looks for a valid http header. If it finds a valid header it just sends it straight through to the client.
Sorry, this probably would have been useful to know for your previous question about sending JSON text.
Jeanette_Fullmer
Hi @Serge A, was Jacob Gillespie's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
sastanin
Thank you @Jacob Gillespie , this solution is working perfectly. And indeed, it's also useful to sending application/json responses.
